Forums -> Technical Support
 LogMeIn Hamatchi - VPN connection problems
If you're having problems getting Easify to connect when using a VPN created with LogMeIn Hamatchi, you need to go into the Advanced network settings of the Hamachi virtual network adapter and change the NETBIOS settings from “default” to “Enabled” on all computers (both holding the database and needing to access the database).
