Forums -> EPOS Hardware
 Till receipts not feeding fully after upgrade to FP6
If you have upgraded Easify to Feature Pack 6 and you find that till receipts do not fully feed through the printer, you will need to set the Post Print Command for your receipt printer.
Note: This only applies to when you are using the ESC/POS printer driver.
Go to Easify Options->Point of Sale->Printing
Set the Post Print Command to 27,100,12,29,86,0,48
  [Missing attachment: PostOpenCodes.PNG]
The first three codes 27,100,12 tell the printer to feed 12 lines after printing.
The last four codes 29,86,0,48 tell the printer to do a full paper cut of the receipt.
Note: If for any reason your printer does not recognise the ESCP/POS line feed commands (27,100,12) you can replace this part of the code with standard ASCII line feed characters (ASCII Code 10). Add a '10' and a comma for each line you want to feed. e.g. to feed 4 lines insert the code 10,10,10,10, at the start of the Post Print Command in place of 27,100,12,.
