Forums -> FAQs (Archived)
 [VIDEO] How to connect MS Excel to the Easify database
Here's another tutorial video for you, in this one I explain how you can connect Microsoft Excel to your Easify database in order to view Easify data in Excel.
This is a great way to create your own customised reports and views of Easify data, and allows you to easily export pretty much any Easify data to CSV file.
For best results, click the 'Watch on YouTube' button in the bottom left of the video and then select the HD option.
Posted by Neiltoo
Re: [VIDEO] How to connect MS Excel to the Easify database
This is really useful thank you.
Is there any way to update the data in the other direction?
i.e. changing prices in the spreadsheet and getting excel to update the database?
Neiltoo said:
This is really useful thank you. :D
Unfortunately it's a one way connection to Excel from Easify so it's not possible to flow data the other way. For products though you can export your data to CSV file and use the Easify product importer to pull the data into Easify.
The following thread explains how to create more advanced Excel reports, using the database language SQL.
http://easify.co.uk/forums/viewtopic.php?f=14&t=902
