Forums -> FAQs
 How do I import a list price or sell price into Easify?
When you import products into Easify, the sell price is calculated for you based on the cost price and margin of the product.
If your product import file doesn't contain a margin column for your products you can add one using a spreadsheet such as Microsoft Excel...
Open your product list CSV file in your spreadsheet application.
Add or insert a column named Margin.
Set the formula for the column as shown below:
Save your modified stock list back to a CSV file, then when you import it into Easify you can map the new margin column to your retail margin or trade margin as desired.
Re: How do I import a list price or sell price into Easify?
This method is no longer required as of Easify Version 3.64 and above.
Posted by j.alvarez
Re: How do I add column to product list?
  How can I customize the product columns and add the following details?
-Expiry Date
-Batch No./Lot No.
-Serial No.
Also in the sales invoice, how can we add a line for discount?
I would be very glad for your reply. Thanks.
Easify currently supports having a serial number field, please read the following articles:
http://www.easify.co.uk/help/hs350.aspx
http://www.easify.co.uk/help/hs870.aspx
Expiry date and batch number are already on our feature request list and will be included in a future update.
Posted by j.alvarez
Thanks a lot John. Looking forward for the feature that you will release because we badly need to track the serial nos and lot nos. for every item/s that we sell/distribute. That's one of the deciding factor for my boss to purchase Easify.
